Old 02-22-2013, 02:50 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Ok.
I haven't measured my AFR at WOT. Is that the only position where it really matters? I was just thinking that it seems like under normal conditions the ECU would probably maintain that 14.7 AFR even with the stock airbox during normal conditions. It would make sense that under WOT I could be lean (since that's what I was doing when I got the lean code that one time) but for the most part it seems like it would be ok where it is?
Just trying to clarify. The car seems to be running fine. I turned the boost off for the time being (jesus these cars are slow without boost, I forgot what that's even like) and am going to get my fiance to help me with the compression test tonight.
Old 02-22-2013, 03:02 PM   #2
Originally Posted by 47_MasoN_47 View Post
Ok.
You are concerned about AFR anytime the needle moves out of the vacuum range and into the boost range. The AFR should decrease proportionally as boost increases. I seldom go near WOT, but at max boost (6 psi) I run about 12. As soon as I cross zero into boost range I see the AFR decrease to about 14.3, and then by 3 psi I am down to about 13.6.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
