Old 02-23-2013, 11:03 AM   #1
hotnoodle
Drives: 2006 Yaris hatchback
Angry
Thanks very much for your help.
I guess there'sa no way of doing it but taking it past a dealership so they can program it.
Looks like ill stick to my other 2 button and grey key with no remote.
Thanks
hotnoodle is offline   Reply With Quote
Old 02-23-2013, 01:57 PM   #2
Thanks
If the portion of the remote that is the main housing with the key is intact, you might want to just swap the portion with the electronics. You can pop the case open with a blade. Then, you will only have to do the DIY process for making the remote keyless entry system learn the new remote, and you will maintain the same key with its transponder.
Old 02-23-2013, 05:24 PM   #3
hotnoodle
Oh hold up I might be misinterpreting what the transponder is.
I though it'sthe chip with the bbattery is attached together with.
The transponder is the imbedded bit on the side that has glue over it?
Would it be wise to try and remove the transponder over to the new blank key in have bought off ebay?
Old 02-23-2013, 05:45 PM   #4
I don't think you could remove the transponder without damaging it. From your description of the problem with the old one, I figured that you could take the remote section and it's cover and stick them on to the old one.
Old 02-23-2013, 08:17 PM   #5
hotnoodle
Anyone ever successfully remove the transponder? It would beworth a try wwouldn't it?
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Yaris 2012 Sedan Key with remote faisalloe General Yaris / Vitz Discussion 5 09-27-2012 10:29 PM
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 11:02 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
