Old 02-26-2013, 06:08 AM   #1
hotnoodle
Drives: 2006 Yaris hatchback
I couldnt help myself and took apart the old key to get to the transponder.
I have replaced and inserted into new key.
I will get the new key cut today.
Thats all im assuming I need to do right? Because I have transferred everything over there shouldnt be any need for programming.
If you can let me know your thoughts Scott?
hotnoodle is offline   Reply With Quote
Old 02-26-2013, 06:12 AM   #2
That is correct - If you can move the transponder over, then the only programming required is the DIY programming of the remote. If you move that over as well, then you won't need to do anything.
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Yaris 2012 Sedan Key with remote faisalloe General Yaris / Vitz Discussion 5 09-27-2012 10:29 PM
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 11:02 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
