0-60 in slow
A watts link is right on the money.
I do have a basic design on the Watts link ready to go once I get clarification from the SCCA on what exactly defines a solid axle. The one thing that is a potential downside is that the parts will weigh 20-30 lbs which might be detrimental to the potential gains. There is no need to weld a beam you only need a solid mount at the lower shock point. I also have a plan for a track bar that is extremely simply to mount and install that would be legal in almost any sanctioned race body. The rear has 2 semi heavy duty tow mounts that have 2 holes already drilled in them that could provide an easy spot to mount a trac bar, the only thing that would be required is a slight reroute on the tailpipe. I do have another idea for a Anti-roll bar but that's going to be secret since it can create a potential failure in the axle over a long period of time. |
#2 | |
http://www.richardaucock.com/astra-s...tive-engineer/
0-60 in slow
^ And there you have the parts I'm going to be using.
Some models of the Chevy Cruze a watts link with a sum total of parts that would cost less then $200 to procure, and require only minor modification to the support beam and stabalizer arms to make them work in the way I'm trying to make them work. |
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
