#1 | |
![]() Drives: 2012 Yaris SE 5-speed Join Date: Mar 2012
The Prius Atkinson Cycle cams have the effect of lowering cylinder pressure due to holding the intake open longer and blowing intake charge back into the intake manifold. Thus the higher compression 13:1 pistons do not result in necessarily higher cylinder pressures that the lower compression ration Yaris pistons.
#3 | |
Basically the dynamic CR of the 1nz-fxe probably isn't that much different than the DCR of the 1nz-fe... 13:1 is a very high static CR to start off on a regular fuel injected motor, ESPECIALLY with the stock cams. It's just too bad nobody's come back and said what's happened.
#4 | |
play every day
Here's a fascinating animation of how Atkinson cycle engines work: http://www.youtube.com/watch?v=hEfOxKmCstg Skip to 2:20 second mark to get past the bullshit. |
#5 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
I've found a FULL 2012 Yaris 1NZ-FE cylinder head super cheap. Now just waiting to hear back if I can have it shipped or if I have to go pick it up. |
0-60 in slow
I wouldn't take the crank having a different part number as meaning anything more then it might not have a standard bolt pattern or it might require a longer snout.
Here is a cutout of a 1nz-fxe from an autoshow. You can see the giant mechanical flywheel, which doesn't have provisions for a starter and you can see the giant start/stop starter on the front of the engine. I seriously doubt that the FXE piston would have any issues in the FE engine aside from the massive increase in compression that would cause some tuning issues. The compression being close to 13:1 doesn't really scare me as long as you can control the tune, which is pretty much only possible with a aftermarket ECU. I've seen 4.6l engines running 12.6:1 on 91 octane its doable just takes more work. The piston being HYPEREUTECTIC doesn't mean it can't handle power it just means the piston is less elastic than a forged piston, meaning when its given a shock like say detonation it doesn't deform as much so if the material sees a strong shock it will crack rather than deform. Hypereutectic pistons have some great properties about them that make them suitable choices for performance oriented situation like the fact they have little heat deformations which means they don't compress and swell as much with heat which means you can run a piston tighter in the bore and you can also run a lighter piston which makes the engine more efficient. |
#7 | ||||
Sooo Pretty!
Not sure how I could 'weld' the 1NZ flange onto the 2AZFE plastic tubing :( I may just have to make/design my own. Luckily you already have the flange I need to weld onto! Last edited by JustDidIt; 03-07-2013 at 11:44 AM. |
#8 | |||
play every day
![]() Quote:
The Atkinson engine is really strange. Did anyone notice that it fires on every revolution? |
| 2010 Prius | tuckevalastin | Off-topic / Other Cars / Everything else Discussions | 60 | 01-13-2009 12:24 PM |
| Stupid prius | KSIbucky | Tracking, Racing, Auto-X Forum | 11 | 09-25-2007 11:07 PM |
| ZPIracing Turbo Pistons | ZPIracing | Forced Induction Forum | 22 | 05-29-2007 03:39 PM |
| And You Thought the Prius Was Expensive! | redyaris | Off-topic / Other Cars / Everything else Discussions | 5 | 05-18-2007 05:11 PM |
| Toyot Prius | YamilR | Photo-Video-Media Gallery | 4 | 02-14-2007 06:54 PM |
