Old 03-03-2013, 04:46 PM   #11
Viperoni
Drives: 2005 Toyota Echo
Originally Posted by etherdude View Post
The Prius Atkinson Cycle cams have the effect of lowering cylinder pressure due to holding the intake open longer and blowing intake charge back into the intake manifold. Thus the higher compression 13:1 pistons do not result in necessarily higher cylinder pressures that the lower compression ration Yaris pistons.
QFT
Basically the dynamic CR of the 1nz-fxe probably isn't that much different than the DCR of the 1nz-fe... 13:1 is a very high static CR to start off on a regular fuel injected motor, ESPECIALLY with the stock cams.
It's just too bad nobody's come back and said what's happened.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
2010 Prius tuckevalastin Off-topic / Other Cars / Everything else Discussions 60 01-13-2009 12:24 PM
Stupid prius KSIbucky Tracking, Racing, Auto-X Forum 11 09-25-2007 11:07 PM
ZPIracing Turbo Pistons ZPIracing Forced Induction Forum 22 05-29-2007 03:39 PM
And You Thought the Prius Was Expensive! redyaris Off-topic / Other Cars / Everything else Discussions 5 05-18-2007 05:11 PM
Toyot Prius YamilR Photo-Video-Media Gallery 4 02-14-2007 06:54 PM
