#1 | |
![]() Drives: Yaris TS 05 Join Date: Jun 2011
Maybe I have to tap de + with the Pin 9 and the - at the Pin 11? |
#2 | |
For the first gen, the red wire with the yellow strip in pin 9 is the high beam wire from the switch. That wire gets switched to ground when the high beams are flashed, so you would use pin 9 as your switched ground wire. You would want to use a relay that you switch the coil of with that wire, and then use the normally open relay contacts to trigger your garage door opener's switch.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
