Old 03-04-2013, 01:53 PM   #1
YodaBird
Drives: Gray
I said what can I do to the car that can reduce pot hole damage, not how I can avoid pot holes
YodaBird is offline   Reply With Quote
Old 03-04-2013, 02:49 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
People answered your question:
I know of nothing you can do to the car to reduce the effect of hitting potholes...
...If your car is stock though, don't worry. Well worry about those wheels, because they bend easily.
The easiest way to help is get tires with lots of sidewall, and wheels that can handle a pounding. The rest of the car should be fine, unless the potholes are the size of the wheel, and with those you should just come to a total stop in the middle of the road and go around.
...and technically, avoiding them is something you can do to the car to reduce pot hole...
Old 03-06-2013, 01:08 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I live in a rural area with some pretty rough dirt roads so I run 15x7 wheels with relatively tall 195/60 series tires, a rear sway bar with strut/shock tower braces front and rear, and the stock suspension height for good ground clearance.
License plate bracket for '09 that doesn't require putting holes in the bumper? BennyLava General Yaris / Vitz Discussion 16 03-10-2013 03:08 AM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
How to fix pot holes. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 4 05-04-2010 04:43 PM
Punching Air Box Holes schreck Performance Modifications 11 05-07-2009 04:59 PM
Speaker grills / holes on the doors. IsLNdbOi Wash, Wax, Detailing, Exterior Repairs 3 09-15-2006 10:28 AM
