#1 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
When I do the Cam and Cam gear swap I would basically have the 1NZ-FE head but still the Prius bottom end. Where someone else with the 1NZ-FE would have to tear into the block and switch the pistons but hopefully leaving the stock 1NZ-FE crank. The 1NZ-FXE Does have different pistons and crankshaft but same rods. Would be really interesting to see if there would be a difference it would make between the 1NZ-FXE and 1NZ-FE crank obviously other than part #s being different.. |
#2 | |
The dynamic CR is apparently 11:1 if you use FXE pistons. I was under the impression that the FE & FXE cranks were the same... or at least the stroke is. Maybe the FXE crank is stronger somehow? To answer your question, it depends. A quick googling seems to say that there's diminishing returns, especially since you're not improving the breathing of the motor and filling the combustion chamber with more air/fuel. One calculator said 6.5% and that's more or less what I read on another site as well... which I think is a bit low, but could be bang on. In any case, a 6.5% increase is 7hp. If possible, I'd go with an overbore Prius piston to help increase displacement at the same time as increasing the CR... that'll help engine breathing, and it'll increase the quench area inside the combustion chamber which should help stop some detonation too.
#3 | ||
1NZ-FE: 13401-21020 1NZ-FXE: 13401-21040 Difference No idea... Quote:
| 2010 Prius | tuckevalastin | Off-topic / Other Cars / Everything else Discussions | 60 | 01-13-2009 12:24 PM |
| Stupid prius | KSIbucky | Tracking, Racing, Auto-X Forum | 11 | 09-25-2007 11:07 PM |
| ZPIracing Turbo Pistons | ZPIracing | Forced Induction Forum | 22 | 05-29-2007 03:39 PM |
| And You Thought the Prius Was Expensive! | redyaris | Off-topic / Other Cars / Everything else Discussions | 5 | 05-18-2007 05:11 PM |
| Toyot Prius | YamilR | Photo-Video-Media Gallery | 4 | 02-14-2007 06:54 PM |
