#1 | |
play every day
Here's a fascinating animation of how Atkinson cycle engines work: http://www.youtube.com/watch?v=hEfOxKmCstg Skip to 2:20 second mark to get past the bullshit. |
#2 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
I've found a FULL 2012 Yaris 1NZ-FE cylinder head super cheap. Now just waiting to hear back if I can have it shipped or if I have to go pick it up. |
0-60 in slow
I wouldn't take the crank having a different part number as meaning anything more then it might not have a standard bolt pattern or it might require a longer snout.
Here is a cutout of a 1nz-fxe from an autoshow. You can see the giant mechanical flywheel, which doesn't have provisions for a starter and you can see the giant start/stop starter on the front of the engine. I seriously doubt that the FXE piston would have any issues in the FE engine aside from the massive increase in compression that would cause some tuning issues. The compression being close to 13:1 doesn't really scare me as long as you can control the tune, which is pretty much only possible with a aftermarket ECU. I've seen 4.6l engines running 12.6:1 on 91 octane its doable just takes more work. The piston being HYPEREUTECTIC doesn't mean it can't handle power it just means the piston is less elastic than a forged piston, meaning when its given a shock like say detonation it doesn't deform as much so if the material sees a strong shock it will crack rather than deform. Hypereutectic pistons have some great properties about them that make them suitable choices for performance oriented situation like the fact they have little heat deformations which means they don't compress and swell as much with heat which means you can run a piston tighter in the bore and you can also run a lighter piston which makes the engine more efficient. |
#4 | ||||
Sooo Pretty!
Not sure how I could 'weld' the 1NZ flange onto the 2AZFE plastic tubing :( I may just have to make/design my own. Luckily you already have the flange I need to weld onto! Last edited by JustDidIt; 03-07-2013 at 11:44 AM. |
#5 | |||
play every day
![]() I'll always be stocking them. Since the design is finalized they can be manufactured as needed. |
#6 | |
![]() Picture of my front strut bar install... shows the layout better. ![]() ![]() I really think I have the clearance to make the 2AZFE intake manifold work or something similar because I don't have much in the way if the intake was routed to the passenger side of the engine as the 2AZFE would if mounted on my 1NZ. ![]() ![]() If the 2AZFE manifold doesn't work, My idea is to create the log style intake with fairly long intake runners. Basically the 1NZ-FE reversed. Such as examples below:
#7 | |||
play every day
![]() Quote:
The Atkinson engine is really strange. Did anyone notice that it fires on every revolution? |
| 2010 Prius | tuckevalastin | Off-topic / Other Cars / Everything else Discussions | 60 | 01-13-2009 12:24 PM |
| Stupid prius | KSIbucky | Tracking, Racing, Auto-X Forum | 11 | 09-25-2007 11:07 PM |
| ZPIracing Turbo Pistons | ZPIracing | Forced Induction Forum | 22 | 05-29-2007 03:39 PM |
| And You Thought the Prius Was Expensive! | redyaris | Off-topic / Other Cars / Everything else Discussions | 5 | 05-18-2007 05:11 PM |
| Toyot Prius | YamilR | Photo-Video-Media Gallery | 4 | 02-14-2007 06:54 PM |
