Old 03-07-2013, 10:33 PM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
it is normal...the way how the manual transmission are designed is that once u put into gears...it is made in helical gears, meaning it is curve and when gears are locked into each other it doesnt make any noise at all...as matter of fact it is very quiet...but for reverse gear...it is made in spurs gear...meaning it is made in straight gears and when we put it into reverse gear. the straight edges are engage and it will make that winding noise...to answer your concern...it is normal to make that sound when u put it in reverse...hope this help..and i am sure that some of us in here agrees to what im saying and some of us here also mentioned the same thing as well :D
walt101786 is offline   Reply With Quote
Old 03-15-2013, 03:10 AM   #2
Sedan
Drives: '08 Manual Yaris Sedan
Hi,
New to the forum. Have the same issue and if you listen to it carefully the noise can be heard when on the first gear at a higher rpm as well. I was told to replace gear oil by my mechanic but that did not take care of the sound.
Anyways, it seems like a normal thing inherent to the Yaris. (did not get the same issue in other cars I have driven).
Sedan is offline   Reply With Quote
Werid Noise When I throw it into Reverse LoudYar General Yaris / Vitz Discussion 12 10-26-2020 04:57 AM
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 06:32 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 05:22 AM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
