This is a first gen, not a second gen, so the wiring is a bit different. The way this is wired, if you turn on the switch for the rear, the fronts are automatically turned on as well, but the fronts can be on without the rear.
![]() Drives: 1,5 ts 2002 Join Date: Mar 2013
Tanks, i'll try that.
I think the relay-solution may apply to the front fog as well, cause its not the bulbs, it wont switch on at all... Again, thanks for the possible solution. |
Just one more question.
Shouldnt the fog light be turned off when i remove the relay? I've removed, and slapped every relay in the under-dash fusebox. But the fog light remained turned on all the time... thank you again for any advice/suggestion. |
The relay is mounted to the side of the fuse box (like it was an afterthought). Are you sure you pulled that one?
![]() This is my fuse box under the dash.. I've pulled all the relays i can see, but none of them made the light turn off. Once again, thank you (and in advance for more tips).. |
#6 | |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
![]() Quote:
Now depending on manufacturer, there are differences on how you can run front fogs in connection with main headlights. VW, BMW and Benz factory front fogs are switched so they turn off when you turn on high beams, but you have turn on at least the parking lights. Renaults are wired to turn the rear fogs off when you restart he car, so you don't drive around blinding people behind you for weeks after you drove through some fog ;) |
| Ebay Fog Light Rant | CTScott | DIY / Maintenance / Service | 65 | 06-13-2022 12:10 PM |
| Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 08:34 PM |
| Any PICS of Fog Light SWITCH Location?? | TRDMarty | General Yaris / Vitz Discussion | 7 | 05-29-2012 03:00 PM |
| WTB: Fog Light Switch or Stalk | Lil Abner | Willing to Buy by private party | 4 | 08-20-2010 08:07 AM |
