Old 03-08-2013, 03:04 PM   #1
TOLMACH
Drives: soarer
^ I am using a FRAM version that looks smth like in the middle above .. retails for like 6 bucks everywhere.. I noticed that filter oustide diameter really varies among producers (smth like =/- couple mm) which does not help (( but still does the job if you are very persistent
Old 03-08-2013, 03:57 PM   #2
The 1NR-FE does not have a can type filer. It has a housing with an insert that goes inside of it, so the filter tool is not one of the typical off-the-shelf ones and the size does not vary. It is 64mm x 14 flats. This is what it looks like:
Old 03-08-2013, 04:52 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Attachment 50039
wth would they do that? is it protection for the fliter from becoming damaged or something?
Old 03-08-2013, 05:19 PM   #4
Jason@SportsCar
Less waste, you only replace the element.
I have a Pure Power filter for the Yaris, which is reusable - although I only use it every other oil change, because I hate taking the time to clean while I am changing the oil.
http://gopurepower.com/site/products...lt.asp#FILTERS
Pure Power manufactures the K&N reusable filter as well: http://www.knfilters.com/oilfilter.htm
Old 03-09-2013, 01:17 PM   #5
Geoff Peace
Drives: Yaris 1.33 litre 2011
Attachment 50039
Thankyou very much for your detailed reply C.T. You say the filter is 64mm. I am given to understand that a 64mm removal tool will not fit and a 65mm. is too large. I have been told that Toyota have made it around 64.5mm. which causes the problem. Have I been told correctly? or will a 64mm. 14 flute tool fit?
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 03-09-2013, 01:49 PM   #6
My understanding was that when Toyota first started using that filter setup that people could not find standard sockets to fit it (the in between 64 and 65 issue). Since then there are Toyota specific ones, like the ones above, which are likely a fraction between 64 and 65mm.
Old 03-10-2013, 02:29 PM   #7
Geoff Peace
Thankyou very much for your help C.T. I have a friend who will be visiting the USA in amonth or so and he has offered to bring me one back.
Old 03-10-2013, 02:52 PM   #8
Very good. If you want it sooner, let me know, and I can ship one to you.
Old 05-24-2013, 02:45 PM   #9
Geoff Peace
Filter removal tool TOY 640 has now arrived. All the way from the USA! Does anyone know the correct tightening torque please? The filter retainer seems to be plastic, so I do not want to over tighten, then again I do not want to undertighten and cause an oil leak.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
