Old 03-10-2013, 05:06 PM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
If you are going to try a really large diameter plenum...large diameter equals low velocity.
Old 03-10-2013, 06:06 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
No, I won't be doing that. First off, there's no room for a larger plenum with this particular manifold design while keeping the air filter under the hood. And second I don't want to go larger. Instead, I'm going to a smaller plenum. The existing one is already almost non existent with that big thick intake tube occupying so much volume...
...and yet that design works great! I believe it is because of the unique configuration with all the runner entrances pointing directly at the bore of the throttle body...
That internal intake tube terminates only a couple of inches in front ot the runner's entrances. So there is very little plenum volume left over.
When I get the part, I'll be able to measure exactly how much smaller if at all by filling both plenums with water. What will be radically different is the profile of the new plenum. I literally dreamed up this crazy idea...
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
