#19 |
Oh crap, I thought the stock seat rails were welded to the seats! Looks like I've got a project to do....
#20 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
thanks butcher,
yup, mine comes with the wedge engineering brackets with the adjustable heights. if they don't sale, itll ended up on my new ride or office :P |
#21 |
![]() ![]() Drives: Yaris 2008 Join Date: Jan 2012
@Mr Miles No they are not welded they are held on by some torx bolt, let me see if i can snap some pics to show what im talking about.
Well After further investigation, Theres a part thats welded or something and cannot be removed ![]() So the part that is welded is in the yellow circle. it goes from one side to the other on the driver side seat. You need to remove the torx bolt in the red circles to get the L bracket off,on the other side i left the L bracket on but just removed the bolts that we're in the Bright green circles ![]() Heres a view of the driver side seat L bracket, this one as stated higher is not removable Here's the passenger side, the L bracket is removable on this side, but where the torx bolt are, is not. ![]() Another view from under the passenger side ![]() ![]() So after a while of figuring out where the screws are and plastic clips on the trim panels heres the result Hope it helps, ill get the size of the torx male socket i used to get the bolts out.The male socket size is a T40. Last edited by Crazy Butcher; 03-18-2013 at 10:20 AM. |
#22 |
![]() Drives: Yaris Sedan Join Date: Sep 2011
After swapping the seats, will the seatbelt & sensor work? looks like there is a wiring loom under the stock seat.
#23 |
@ Banifesto To get that problem resolved, you have to buy a module Sensor bypasser, you can check it out on Microimage's site, it just plugs in your black box under the passenger seat,when you remove the oem seat you have to unplug a connector off of the black box to get the seat out. just plug the new module right there, then you can switch it on and off. Also the modules are made by CTScott, Shoutout to him by the way!
#24 |
Thanks for the info Crazy Butcher :)
| are all bride and recaro seats can be used in yaris sedan 07? | gudboi182 | Performance Modifications | 5 | 03-05-2012 04:47 PM |
| Supercharger, Nardi wheel, Recaro seats!!! | jdmekcivic | Items for Sale by private party | 165 | 11-18-2010 12:37 AM |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| Need Seats Opinions Wanted | RacerFreakXXX | Cosmetic Modifications (Exterior/Interior) | 9 | 02-15-2009 02:15 AM |
| FS: Recaro Pole Position Racing Seats (black) -- socal | 03Z33 | Items for Sale by private party | 13 | 12-07-2008 05:08 PM |
