Old 02-28-2012, 05:47 AM   #1
gudboi182
lovedrunk
Drives: vios 07
are all bride and recaro seats can be used in yaris sedan 07?
i know a stupid question. lol
gudboi182 is offline   Reply With Quote
Old 02-28-2012, 08:53 AM   #2
vten
I believe so , it just depends on how much are you wiling to spend ... All you need is just make the custom seat bracket to mount the seat to your car .
Old 03-03-2012, 02:53 PM   #3
3cyltrbo
You'd be well advised to contact MicroImageOnline (board sponsor) they can help
in the meantime (from my research because I'm also thinking about seats) this is what I think is involved.
wedge engineering (or similar) brackets bolt to the unibody / then you can bolt a universal slider mechanism to those brackets (like the recaro or sparco sliders) / then you bolt the seat (with its own brackets) to the sliders
Someone who has done it differently, or has another recommendation please advise .....................
3cyltrbo is offline   Reply With Quote
Old 03-03-2012, 07:25 PM   #4
You can also connect Wedge brackets directly to the seats, but most people want the slider capability. You can also get height adjustment front.rear with the brackets, depends on which ones you order.
We can take care of the whole thing for you, it's what we do. :)
Old 03-05-2012, 04:19 PM   #5
3cyltrbo
so was I right?
wedge bracket to the unibody -- then sliders to the wedge engineering brackets -- then recaro or other seat bracket to the sliders????
Also, what did you do in order to keep the OEM seatbelts when you put your Brides in? / did you re-use the OEM seatbelt and bolt it to the Bride or the Unibody 0f the car?
Will
Old 03-05-2012, 04:47 PM   #6
The Wedge brackets will include a hole to bolt the inside seat belt in (the female part). The outside seat belt hole is obviously on the frame.
Just got my Yaris: some questions botchilah General Yaris / Vitz Discussion 7 02-15-2009 09:04 PM
Need Seats Opinions Wanted RacerFreakXXX Cosmetic Modifications (Exterior/Interior) 9 02-15-2009 02:15 AM
