Old 03-22-2013, 09:42 AM   #1
skoya
skoya's Avatar
Drives: Yaris 1.0L
That is left under from the steering wheel,when I remove the panel,right?
skoya is offline   Reply With Quote
Old 03-22-2013, 09:46 AM   #2
Yes - If your car is left hand drive it is to the left of the steering wheel and and it is under the bottom of the dash, so you look up from the floor to see the cover, which has the labels.
Old 03-24-2013, 05:08 PM   #3
skoya
skoya's Avatar
Drives: Yaris 1.0L
Ok Scott,
I have checked the fuses,they are Ok.I disassembled the cluster,and there where no bulbs.What now?
Old 03-24-2013, 05:19 PM   #4
Ok Scott,
What parts of the instrument cluster are still working properly?
Old 03-24-2013, 05:36 PM   #5
skoya
skoya's Avatar
Drives: Yaris 1.0L
Everything works as it should be,only this right corner,where the clock,trip computer and the MPG shows,that part is out of light.When I took apart the cluster,I notice that this particulary part containes small LCD display which is attached to this connector.And behind that is small circuit board that controls it.I did not see any bulbs.Maybe it is an electrical failure,or something like that.
Old 03-24-2013, 08:33 PM   #6
OK. It does sound like a failure of a portion of the cluster's circuitry. If you have the owners manual for you car, take a look to make sure that it is not simply a case where you can some how turn off those items.
Old 03-25-2013, 04:57 AM   #7
skoya
skoya's Avatar
Drives: Yaris 1.0L
I have both owner's and repair manual,and I can't see nowhere that problem.
Altought I've downloaded the owner's manual,and it's only for US and Canada models.European couldn't find nowhere.I need it exactly for digital cluster,anything else is useless.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
