Old 03-25-2013, 04:57 AM   #1
skoya
skoya's Avatar
Drives: Yaris 1.0L
I have both owner's and repair manual,and I can't see nowhere that problem.
Altought I've downloaded the owner's manual,and it's only for US and Canada models.European couldn't find nowhere.I need it exactly for digital cluster,anything else is useless.
skoya is offline   Reply With Quote
Old 03-25-2013, 07:57 AM   #2
I have parts of the European service manual, but it does not indicate being able to turn off the clock. Sometimes the owners manual has some additional information on those kinds of "features".
Old 03-25-2013, 08:11 AM   #3
skoya
skoya's Avatar
Drives: Yaris 1.0L
I don't know man,what can I do?Do you have something else on your mind?
Any answer is a welcome.
Old 03-25-2013, 08:19 AM   #4
Other than one of the connectors having been loose, I can't think of anything else that you can easily check. At this point, if you can find someone with another Yaris with a digital cluster, you could try swapping the two to verify that the problem is with the actual cluster.
Old 03-25-2013, 09:03 AM   #5
skoya
skoya's Avatar
Drives: Yaris 1.0L
I will try with this connector,but not today.I will have to wait til weekend.
We don't have much Yaris in my town,so the second option falls thru.
By the way,I forgot to tell you,there is a smaller connector that connects speedo gauge with the hausing,or something like that.Anyway I will try to do something.Thank's again.
Old 03-25-2013, 10:44 AM   #6
I happen to have a European digital cluster that I imported to experiment with. When I have a chance I will open it up and see if there is anything that I can think of that would cause the behavior you are seeing.
Old 03-25-2013, 11:21 AM   #7
skoya
skoya's Avatar
Drives: Yaris 1.0L
Great,you do that,thanks.Then send me a PM.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
