Old 03-25-2013, 09:03 AM   #1
skoya
skoya's Avatar
Drives: Yaris 1.0L
Other than one of the connectors having been loose, I can't think of anything else that you can easily check. At this point, if you can find someone with another Yaris with a digital cluster, you could try swapping the two to verify that the problem is with the actual cluster.
I will try with this connector,but not today.I will have to wait til weekend.
We don't have much Yaris in my town,so the second option falls thru.
By the way,I forgot to tell you,there is a smaller connector that connects speedo gauge with the hausing,or something like that.Anyway I will try to do something.Thank's again.
skoya is offline   Reply With Quote
Old 03-25-2013, 10:44 AM   #2
I happen to have a European digital cluster that I imported to experiment with. When I have a chance I will open it up and see if there is anything that I can think of that would cause the behavior you are seeing.
Old 03-25-2013, 11:21 AM   #3
skoya
skoya's Avatar
Drives: Yaris 1.0L
Great,you do that,thanks.Then send me a PM.
Old 03-29-2013, 10:43 AM   #4
skoya
skoya's Avatar
Drives: Yaris 1.0L
Here is the cluster and the clock on the right side
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
