Old 03-29-2013, 09:16 AM   #1
Originally Posted by mitch2008 View Post
hey no its part of the OD and trip button. It is suppose to go through trip 1, then trip 2, then brightness control, then back to OD but it does not do that all of the time. I have a feeling its the dimmer switch as well but also wanted to check the fuse which is crazy hectic to get out. What can I use to remove that thing? Thank you for your help.
If you look in the under-hood fuse panel there should be a white plastic "tool" for pulling the fuses. If it is missing, you can carefully use a pair of needle nose pliers.
Dashboard lights turn off when I turn use headlights patate15 DIY / Maintenance / Service 7 07-05-2020 03:05 AM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Changing dashboard lights gm830 Cosmetic Modifications (Exterior/Interior) 5 01-31-2012 11:00 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Interior dashboard lights Westlander DIY / Maintenance / Service 3 10-20-2010 09:29 AM
