Old 03-30-2013, 10:49 PM   #1
Spacers will most likely get rid of the inner rubbing. Just make sure you don't go wider than the 5mm you have now unless you get extended studs. Also, make sure you check the torque on the nuts once a week at least after installing spacers.
Rubbing Issues RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-12-2010 08:26 PM
Will Rubbing Occur on DF210's/ Motegi 17x7, ET40 with Nexen n3000 205/40ZR17 areithan1980 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-16-2009 10:52 AM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
"Bouncy" Ride After DF210s? MadMax Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 05-12-2009 10:04 AM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
