That black spot does appear to be a normal part of how they manufacture the VFDs.
Since it is custom I can't find a data sheet for it. It would have been good if I could so that we could take some comparative measurements to determine if that is what is bad on yours.
#2 | |
![]() Drives: Yaris 1.0L Join Date: Mar 2011
The driver circuitry is actually on the bottom of the large board (where the large can shaped devices are). The small board on the back is the core board where the odometer data is stored and the main processor is located. I believe that that one is fine.
Ok Scott,here on this pic you can see these three transistors or whatever they are,seems to be burned.You can tell by their middle pins.I have isnpected them with ohmmeter,and the current flows on both sides instead of one.They are type MK 58.So when I turned the cluster on the other side,you can see clearly brown spots on this green pattern.Can you confirm that this could be the problem.You can see them right in the bottom middle section.
#5 | |
#6 | |
And i need some characteristics for this type. |
I am not sure. The MK alone is not enough information.
| GI: "YarGauge" replacement clock module (Digital Tach, etc.) | CTScott | Items for Sale by private party | 756 | 03-21-2013 09:22 PM |
| 05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 05:34 AM |
| Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 10:22 AM |
| Dashboard remove ... ALL of it | Toji | Cosmetic Modifications (Exterior/Interior) | 7 | 02-26-2011 07:30 AM |
| Setting the clock after DST change | ToddR | DIY / Maintenance / Service | 10 | 03-10-2009 12:33 AM |
