Old 04-03-2013, 01:00 AM   #11
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Lights are on, heating is on or AC all the time but I see the volt-meter at:
14.1 v in iddle
13.9 v cruising
It's not about sound level, it's just the Center Image that moves 2 or 3 inches left or right.
Thanks
D.
Where's your voltmeter connected ?
If you say battery that still isn't what the amps seeing...since you have 3 amps.
You have a 4 channel amp correct ? 2 channels per each side correct ? I'm going to ask a question, if you messed with the gains on one of the L or R channels of that amp...would it move the image ?
