Old 04-06-2013, 01:01 PM   #1
fast2882
Drives: Toyota Yaris 2012
maybe piston hit the valve
fast2882 is offline   Reply With Quote
Old 04-08-2013, 01:18 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by Golddeenoh View Post
what would go first the cylinder walls or the connecting rods?
Doubt either...
Possible.. Would def want to clay before starting the car.
A lot of this is repeat from other threads..but seems very feasible:
Originally Posted by Viperoni
The (static) CR would be 13:1 if you use Prius (FXE) pistons.
The dynamic CR is apparently 11:1 if you use FXE pistons
The most I may need to change when running 11:1 compression is 91 instead of 87 pump gas, besides some EM. But even then....I run on 87 now...at the supposed static CR of 13:1 or dynamic 11:1.
List of Different Parts:
Crankshaft:
1NZ-FE: 13401-21020
1NZ-FXE: 13401-21040
Cam 1:
1NZ-FE:13502-21031
1NZ-FXE: 13502-21021
Cam 2:
1NZ-FE:13501-21030
1NZ-FXE: 13501-21060
Cam Gear:
1NZ-FE: 13050-21041
1NZ-FXE: 13050-21051)
Rings:
1NZ-FE: 13011-21041
1NZ-FXE: 13011-21100
Pistons:
1NZ-FE: 13101-21070
1NZ-FXE: 13101-21110
Valve Springs:
1NZ-FE: 90905-01049
1NZ-FXE: 90501-23135
List of parts that ARE the same...
Sprocket:
1NZ-FE: 13050-21041
1NZ-FXE: 13050-21041
Timing Chain:
1NZ-FE: 13506-21050
1NZ-FXE: 13506-21050
Rods:
1NZ-FE: 13201-29735
1NZ-FXE: 13201-29735
Bearings: all three SAME
13041-21022-01
13041-21022-02
13041-21022-03
Cylinder Head:
1NZ-FE: 11101-21062
1NZ-FXE: 11101-21062
Engine Block:
1NZ-FE: 11401-29856
1NZ-FXE: 11401-29856
Valves Seals:
1NZ-FE: 90913-02092
1NZ-FXE: 90913-02092
Intake Valves:
1NZ-FE: 13711-21010
1NZ-FXE: 13711-21010
Exhaust Valves:
1NZ-FE: 13715-21010
1NZ-FXE: 13715-21010
JustDidIt is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
