Old 07-18-2012, 10:52 PM   #1
Nanoss22
Drives: Yaris sedan 10 std...
prius piston swap
Sorry for the delay... just done it today and it works perfectly no mods requiered now some good breaking and dyno cooming soon...
Nanoss22 is offline   Reply With Quote
Old 07-18-2012, 10:58 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
how much driving have you done and can you feel a difference?
Old 07-19-2012, 12:08 AM   #3
Viperoni
Drives: 2005 Toyota Echo
Is any tuning required, and is 91 octane gas required?
Can't wait to see the numbers! :)
2006 Saturn Ion Redline
Old 07-19-2012, 12:56 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
finally someone is straight up doing it!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-19-2012, 05:24 PM   #5
Nanoss22
No modification needed just 91 gas from now foward i have a apex safc for the air fuel ratio and yes i can tell it feel diferent
Old 07-19-2012, 05:34 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
how much of a difference? Any dynos? Why 91 required?
Old 07-19-2012, 06:51 PM   #7
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Because his compression ratio is now close to 13:1 !!!
I too am anxious to see how it does. Are you going to run the stock camshafts?
Old 07-19-2012, 06:55 PM   #8
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Killer ! Did you use the yaris rods or the prius ones ? Also what apexi safc are you using , afc2 or the neo ?
Old 07-19-2012, 11:09 PM   #9
Nanoss22
The safc2 i just install the pistons yesterday now i am in breaking mode... I use the 1nz fe rods all internals are original i have some mods like 1zz trhtle ebay intake with velocity costum echo header 2" catless ending with magnaflow freeflow 2 1/4 exhaust the last time i did the dyno pull without fixing the afr 111whp if you guys are excited i am crazy to tune it to see the gains... the thing is that i have a lot of mods to get done to get the max hp so they are cooming soon
Old 07-25-2012, 01:37 AM   #10
fast2882
Drives: Toyota Yaris 2012
Hi Guys, i am from Jakarta Indonesia, and really interested with this thread. Wow... finally, 1nz-fxe piston in 1nz-fe engine. Are you sure it is save for the clearance between the piston and valves?
fast2882 is offline   Reply With Quote
Old 07-25-2012, 03:14 PM   #11
Nanoss22
1 week and no problems it feel great i am jus giving some miles for the breaking they fit perfectly...
Old 07-25-2012, 04:53 PM   #12
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
so you were getting 111hp before the pistons? that is awesome. I would love to see what just the pistons did. I understand that dyno runs cost so most of the time it isn't cost effective to do multiple dyno runs inbetween mods.
I can't wait to see what you get out of this thing.
Old 07-26-2012, 11:43 AM   #13
fast2882
so, really don't have any problem with the clearance between valve and pistons? wow.... do you know what your car compression ratio ? 13:1?
Old 07-26-2012, 11:51 AM   #14
fast2882
Here in Indonesia, tuner have tested on Yaris that the head can be milled for maximum 1mm and the compression ratio become around 11.5:1. If this piston swap is successful, than this can become the highest compression ratio for 1nz-fe gasoline engine. Please dyno run to see the gain?
Old 07-26-2012, 11:52 PM   #15
Nanoss22
In puerto rico i have some friends with yaris hb with the prius pistons swap i am waiting for them forthe dynoo numbers.. They have other mods that i would like to do if i see the gains with those mods.. the max hp that i got with mi car was 114 with the apex tuneup the last time the heat in the dyno afected the numbers 108 in that run my old apex vafc at 5000rpm it wasnt setting up and the airfuel ratio was going down to 12 very rich at fuel now with the apex safc i am expecting new numbers and no problem with the airfuelratio... Btw in this mods the head canot be touch so the valve and piston clearence well you can see it in the pics
Old 07-27-2012, 12:05 AM   #16
fast2882
My Yaris head is still factory std, so i can do the piston swap too, but i'm still really curious for your compression ratio, is it really 13:1 and still don't have detonation problem using 91 pump gas?
Old 07-27-2012, 12:15 AM   #17
fast2882
Wow... 13:1 street 1Nz-Fe, cast piston, the compression ratio is similar to mazda sky active newest technology
Old 07-27-2012, 07:00 AM   #18
Flipper_1938
Everything I have seen lists the 1NZ FXE engine at 13:1 compression ratio!
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
