Old 04-11-2013, 08:27 AM   #1
Originally Posted by dinop View Post
A friend gave me this keyless entry/remote starter kit last night, and it does have an auxiliary function, put it only puts out positive power. I'm thinking of skipping the headache and putting the factory keyless entry (for the two door hb) in my sedan since the remote is shaped for the guts of a toyota key anyway. Any resources you would recommend for parts/diy installation?
There's a thread on here where all of the parts required are listed. You'll have to do a bit of searching to find it. The part though are very expensive for an OEM keyless install, as you need the receiver (which is very hard to find and crazy expensive when you do) and the body ECU (which is part of the under dash fuse panel).
Tags
delayed headlights, flip key, keyless, remote, trunk release
Help with replacing 2 button key remote hotnoodle DIY / Maintenance / Service 22 12-18-2016 05:26 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
