Old 02-23-2013, 07:28 AM   #1
hotnoodle
Drives: 2006 Yaris hatchback
Help with replacing 2 button key remote
Hi all,
I'm new to all this so please excuse my lack of knowledge here
I have a 2 button remote key that needs replacing as the buttons are starting to fall off. I have bought a 2 button replacement remote key off ebay for $10.
Has anyone replaced one of these before?
Is it as simple of getting the key cut, moving the transponder over?
I'm not sure about how to remove the immobiliser from the key and dont want to damage it in the process.
It looks like it is in the side of the key with some kind of glue over it.
Does anyone have any ideas that would help?
Also is that all that needs to be done so that it will work?
thanks in advance!
hotnoodle is offline   Reply With Quote
Old 02-23-2013, 08:22 AM   #2
In the DIY section of this forum there are a couple of threads that explain how to "teach" the system the new remote. For the key itself, having that cut can be done by any locksmith or your dealer, but the transponder is embedded into the plastic, so you will have to have the dealer program the system for the new transponder, as there is not a DIY method of doing that (it requires the Toyota TechStream service tool).
Old 02-23-2013, 12:03 PM   #3
hotnoodle
Angry
Thanks very much for your help.
I guess there'sa no way of doing it but taking it past a dealership so they can program it.
Looks like ill stick to my other 2 button and grey key with no remote.
Thanks
Old 02-23-2013, 02:57 PM   #4
Thanks
If the portion of the remote that is the main housing with the key is intact, you might want to just swap the portion with the electronics. You can pop the case open with a blade. Then, you will only have to do the DIY process for making the remote keyless entry system learn the new remote, and you will maintain the same key with its transponder.
Old 02-23-2013, 06:24 PM   #5
hotnoodle
Oh hold up I might be misinterpreting what the transponder is.
I though it'sthe chip with the bbattery is attached together with.
The transponder is the imbedded bit on the side that has glue over it?
Would it be wise to try and remove the transponder over to the new blank key in have bought off ebay?
Old 02-23-2013, 06:45 PM   #6
I don't think you could remove the transponder without damaging it. From your description of the problem with the old one, I figured that you could take the remote section and it's cover and stick them on to the old one.
Old 02-23-2013, 09:16 PM   #7
hotnoodle
Cool. So if I can remove the remote section and get the new key blade cut. All ill need is the transponder right? I'm guessing this will be quite expensive from Toyota. Then once I get that, I need to get it programed to go with my immobiliser (opening/closing doors etc)
Old 02-23-2013, 09:17 PM   #8
hotnoodle
Anyone ever successfully remove the transponder? It would beworth a try wwouldn't it?
Old 02-23-2013, 11:00 PM   #9
First verify where the transponder is located. Pull the electronics out of your remote and then see if the engine will start with the empty key. Also, are you positive that your 2006 has the transponder key?
Old 02-24-2013, 07:32 AM   #10
hotnoodle
Im assuming it would... ill take a picture and post it up tomorrow for you to see... I will also give that a try... by removing the electronics your referring to the remote right? where the battery is connect to it?
Old 02-24-2013, 08:17 AM   #11
Correct - The remote is basically a chunk with the battery that easily separates from the rest.
Old 02-26-2013, 12:14 AM   #12
hotnoodle
Heres the photo... sorry for the late reply
Old 02-26-2013, 12:17 AM   #13
hotnoodle
where the screwdriver is pointing is where im guessing the transponder is right?
Old 02-26-2013, 12:19 AM   #14
The slot by your screwdriver tip is where I believe the transponder lives. I have a non-transponder one and that slot empty. I think I also see the little round indent near the head of the metal key, which designates that a key is the transponder type.
Old 02-26-2013, 03:01 AM   #15
hotnoodle
Great. I got my replacement key today and was thinking of attempting to remove the transponder. If successful it means I won't need to program it once I swap it over right? It should work once I have cut the key?
Old 02-26-2013, 07:08 AM   #16
hotnoodle
I couldnt help myself and took apart the old key to get to the transponder.
I have replaced and inserted into new key.
I will get the new key cut today.
Thats all im assuming I need to do right? Because I have transferred everything over there shouldnt be any need for programming.
If you can let me know your thoughts Scott?
Old 02-26-2013, 07:12 AM   #17
That is correct - If you can move the transponder over, then the only programming required is the DIY programming of the remote. If you move that over as well, then you won't need to do anything.
Old 02-26-2013, 07:14 AM   #18
hotnoodle
This is the photo of the transponder in the new key housing.
Hopefully i didnt damage it!
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 07:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 06:04 AM
Yaris 2012 Sedan Key with remote faisalloe General Yaris / Vitz Discussion 5 09-27-2012 11:29 PM
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 12:02 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 08:29 PM
