Old 04-17-2013, 08:15 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Mine goes from 2 bars to flashing I don't seem to have 1 bar
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 04-17-2013, 08:21 PM   #2
The single bar only appears flashing.
Old 04-25-2013, 05:28 AM   #3
lamadoo
Drives: 2007 Yaris 3door white
Was reading some past threads.
I read that we should not let it drop to 1 bar (blinking). Always try and keep it at minimum 2 bars because you don't want your yaris running low and on fumes. All the gunk in the fuel filter will get stirred and stuff, if someone with more knowledge can explain better.
The fuel filter is extremely difficult to change, some say its unserviceable so we should take care of it and use decent fuel on top
lamadoo is offline   Reply With Quote
Old 04-25-2013, 07:33 PM   #4
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
Also keep in mind that some of us have had problems with the fuel gauge not reading correctly, so that it reads as 1/4 full, but you're almost out of gas. Keep track of your miles with the odometer so you don't run out of gas.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 03-11-2015, 11:54 AM   #5
Jcp123
Drives: '00 Echo
I have this problem as well in my Echo. Sucks.
Jcp123 is offline   Reply With Quote
Old 04-25-2013, 10:00 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
That depends on what your car is doing. I wait to the bar is flashing to fill it, and I have never had to put more than 10.5 gallons in. An entire gallon is plenty extra.
But that is my car, all Yaris' seem to be different in this regard.
Colin Chapman disciple
Tags
fuel gauge
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
