Old 04-19-2013, 09:34 PM   #1
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
so back to this:
its a wired in 10amp fuse pre wired on the AEM F/IC harness. where does it go?
yariSB86 is offline   Reply With Quote
Old 04-20-2013, 01:47 AM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Originally Posted by yariSB86 View Post
so back to this:
My FIC harness didn't have that prewired. However, AEM likely revised their harness in the last few years to include it because people were probably hooking up their FICs unfused. Thus, if wired incorrectly - the unit gets fried, and AEM is left having to replace it.
As for where it goes, you have quite a few options at the fuse box in the engine bay. Ideally, you'll want to hook it up in place of another 10 amp fuse that only receives power on ACC or IGN. I'd check ECTS and EFI2 to see if they have voltage on key off, I can't remember.
Even if you have a constant 12v, the FIC has very little parasitic drain (pretty sure I actually have mine hooked up to a constant 12v).
Also, drilling the block - not as daunting as it sounds. Use the fittings I have in my guide, seal it up with some permatex, and you'll be fine.
Keep it up! It's worth it in the end
Focus_Sh1ft is offline   Reply With Quote
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
