Old 04-26-2013, 07:19 PM   #1
Originally Posted by Diagnostic View Post
Hi Scott
I have a 2013 998cc UK 'Edition' (base model) Yaris and would love to fit cruise, is it possible to fit the ECM based kit to my car and if so do you supply the complete kit Scott?
All the best.....
My understanding is that only the 1.33L 2012+ European Yaris supports cruise control. Do you know if cruise is offered as an option on any of the UK 998cc Yaris?
Old 04-27-2013, 08:33 AM   #2
Diagnostic
Diagnostic's Avatar
Drives: Yaris 5dr 998cc Edition 2012
Unhappy
Unfortunately after contacting the main dealer today, they have said the 998cc is not equipped with cruise for the UK. If I were to fit an aftermarket cruise system it would affect my warranty. Well I'm not worried about that but am a little cost conscious, a Google search last night revealed the price is likely to be circa £500 ($750)
Diagnostic is offline   Reply With Quote
Old 04-27-2013, 09:13 PM   #3
I have noticed as well that the aftermarket cruise control options for European Yaris are crazy expensive. I believe that the Rostra system, which was the dealer installed cruise control option for the US for 07-08 Yaris, will work on European Yaris, nut I have not had the opportunity to test the theory yet. The Rostra kits were about $250. I actually have one of the kits in my possession, and really need to coordinate doing some experimentation on one of my European trips.
Old 04-28-2013, 09:45 AM   #4
Diagnostic
Diagnostic's Avatar
Now I'm really confused or dense; I've been assured the Rostra 250-1836 cruise stalk and the 250-4206 clutch switch will work with my car. I don't see how as its only the switches and a few wires, if the car is not pre-wired and configured theirs nothing smart for the cruise stalk to talk to. Is that right? Or am I both confused and dense? Perhaps this seller wants me to add gullible?
Information provided by: Kartronix- eBay item: 261180202724
Old 04-28-2013, 09:10 PM   #5
The Rostra 250-1836 definitely will not and the 250-4206 is just the clutch switch. It is the same as what I sell (but for much more money). The Rostra kit that I believe will work is the discontinued one that used a smaller stalk that mounted to the opposite side of the steering wheel and had a green LED on the stalk. That kit includes a control box that does the cruise control functionality (which your ECM lacks) and is does so by intercepting and overriding the throttle pedal signals.
Old 05-05-2013, 03:35 AM   #6
Diagnostic
Diagnostic's Avatar
Hi Scott. The now obsolete unit you mentioned above; do you have a model number and I'll try and locate one on FleaBay or alternatively perhaps you can provide the kit yourself?
Really, really want to have cruise on my 998cc
Regards
Old 05-05-2013, 08:48 PM   #7
Regards
I can work with you with the kit that I have. We just need to verify a couple of things to confirm my theory before I ship it. I will PM you my email so we can work directly on some photos that I will need.
Old 01-02-2014, 03:32 PM   #8
jackab
Drives: 2011 Yaris Hatchback
Hi Scott, I have a 2011 Yaris Hatchback, MT, and have been trying to install a Rostra cruise control. I've put in the 250-1836 and the clutch switch. It seems I don't need the ECM hookups and have not put them in. The light comes on at my dash, but the cruise control doesn't work. It sounds like I should just toss it and buy yours. If so, would you want all of this Rostra stuff? Any other tips? Thanks for being out there! Wish I'd found you before messing with Rostra!
jackab is offline   Reply With Quote
Old 01-02-2014, 05:18 PM   #9
If the cruise symbol lights up, then you are good for the ECM connection. If your can't get the "SET" light to come on (and the cruise to actually work), then the clutch switch may not be installed correctly.
The clutch switch needs to be fully depressed when the clutch pedal is not touched in order for cruise to work. If you installed the switch in too far, then it will not actuate when the clutch is at rest and therefore will not allow cruise to work.
The Rostra 250-1836 kit is essentially identical to what I sell, but for a whole lot more money. (The older kits were a custom Rostra product, but the new ones are just the OEM switch, etc.)
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
