Old 04-28-2013, 09:45 AM   #1
Diagnostic
Diagnostic's Avatar
Drives: Yaris 5dr 998cc Edition 2012
I have noticed as well that the aftermarket cruise control options for European Yaris are crazy expensive. I believe that the Rostra system, which was the dealer installed cruise control option for the US for 07-08 Yaris, will work on European Yaris, nut I have not had the opportunity to test the theory yet. The Rostra kits were about $250. I actually have one of the kits in my possession, and really need to coordinate doing some experimentation on one of my European trips.
Now I'm really confused or dense; I've been assured the Rostra 250-1836 cruise stalk and the 250-4206 clutch switch will work with my car. I don't see how as its only the switches and a few wires, if the car is not pre-wired and configured theirs nothing smart for the cruise stalk to talk to. Is that right? Or am I both confused and dense? Perhaps this seller wants me to add gullible?
Information provided by: Kartronix- eBay item: 261180202724
Diagnostic is offline   Reply With Quote
Old 04-28-2013, 09:10 PM   #2
The Rostra 250-1836 definitely will not and the 250-4206 is just the clutch switch. It is the same as what I sell (but for much more money). The Rostra kit that I believe will work is the discontinued one that used a smaller stalk that mounted to the opposite side of the steering wheel and had a green LED on the stalk. That kit includes a control box that does the cruise control functionality (which your ECM lacks) and is does so by intercepting and overriding the throttle pedal signals.
Old 05-05-2013, 03:35 AM   #3
Diagnostic
Diagnostic's Avatar
Hi Scott. The now obsolete unit you mentioned above; do you have a model number and I'll try and locate one on FleaBay or alternatively perhaps you can provide the kit yourself?
Really, really want to have cruise on my 998cc
Regards
Old 05-05-2013, 08:48 PM   #4
Regards
I can work with you with the kit that I have. We just need to verify a couple of things to confirm my theory before I ship it. I will PM you my email so we can work directly on some photos that I will need.
Old 01-02-2014, 03:32 PM   #5
jackab
Drives: 2011 Yaris Hatchback
Hi Scott, I have a 2011 Yaris Hatchback, MT, and have been trying to install a Rostra cruise control. I've put in the 250-1836 and the clutch switch. It seems I don't need the ECM hookups and have not put them in. The light comes on at my dash, but the cruise control doesn't work. It sounds like I should just toss it and buy yours. If so, would you want all of this Rostra stuff? Any other tips? Thanks for being out there! Wish I'd found you before messing with Rostra!
jackab is offline   Reply With Quote
Old 01-02-2014, 05:18 PM   #6
If the cruise symbol lights up, then you are good for the ECM connection. If your can't get the "SET" light to come on (and the cruise to actually work), then the clutch switch may not be installed correctly.
The clutch switch needs to be fully depressed when the clutch pedal is not touched in order for cruise to work. If you installed the switch in too far, then it will not actuate when the clutch is at rest and therefore will not allow cruise to work.
The Rostra 250-1836 kit is essentially identical to what I sell, but for a whole lot more money. (The older kits were a custom Rostra product, but the new ones are just the OEM switch, etc.)
Old 01-03-2014, 09:42 PM   #7
jackab
Cool
I checked the clutch, and it looked like the clutch pedal was depressing it enough, but I extended it a bit more anyway. The cruise control still didn't work. I removed the clutch switch wires and went for another drive. Cruise control still didn't work even though the cruise control dash came on. When installing the kit, it seemed too simple an installation for the cruise control to actually work. Does the device send radio signals to the ECM to tell it what to do?
Old 01-03-2014, 09:49 PM   #8
When you say you removed the clutch switch wires, did you unplug the OEM connector that was taped to the harness just above the clutch pedal, or did the Rostra kit include its own wiring for the clutch?
The stalk is a wired connection to the ECM. It is simply four switches and three resistors and the ECM sees the voltage drop across the resistor when one of the switches is pressed. The clutch switch is also a switch input to the ECM, which routes through one of the connectors in the under-hood fuse panel to get there.
Old 01-05-2014, 11:56 PM   #9
jackab
The Rostra instructions said to splice the two wires from the clutch switch to the two wires leading to the A29 connector. The connector was taped up out of the way and was not connected to anything. The CC should work without the clutch switch installed, so I disconnected those wires. Still, the dash CC indicator light comes on and CC doesn't work. I will next take the airbag off and make sure everything is done right there, but it's so simple that even I should be able to get it right.
I installed one of the old style Rostra CC units in my 2010 Yaris, and it works well. It cost a lot more and is more elaborate. The 2011 Yaris belongs to my wife. Her knee is hurting her, and the cruise control helps a lot, so we need to get it going. (You probably didn't need to know all that.)
Thanks for all your time and help.
Bill Foreman
Moab, UT
Mountain Biking Capitol
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
