Old 04-29-2013, 12:20 AM   #1
NaviLupets
Drives: toyota yaris
does the new lighter weight pulley do damage because it absorbs less vibration?
NaviLupets is offline   Reply With Quote
Old 04-29-2013, 03:50 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
no, 4 cylinder engines are balanced vertically and don't have the need for a harmonic balancer like many "V" type engines. it wont hurt your engine unless you install it incorrectly.
Old 04-30-2013, 09:30 PM   #3
NaviLupets
how long have u had your pulley installed for? cuz i have been reading a bunch of articles and it says that it will damage your engine. trust i would love to buy that part and install it but I'm looking for more evidence that it wont.
Old 04-30-2013, 11:36 PM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
9 months, no problems whatsoever. Only issues I've heard about it is getting the belt at the right tension after installing it (happened to me, too). Not a biggie, the belt squeaks a little and you tighten it up!
NST made a similar version of this pulley back in the day, people have run them for tens of thousands of miles without any issues. The MI one is a bit better from a build point of view, so you should be good to go for the life of your Yaris.
Edit: What tk-421 said!
Old 05-01-2013, 12:39 AM   #5
Astroman
Modded Moderator
Astroman's Avatar
90k miles, improved engine response, less gear hunting in the automatic when climbing hills, improved MPG and ZERO issues. I'm using the nst version and can say without a doubt a very worthwhile and noticeable modification. Laws of physics apply here, less rotational mass!
diy, light weight, microimage, pdf, pulley
Crank Pulley DIY? Captain Slow Performance Modifications 2 06-07-2012 12:58 PM
DIY - NST CR lite pulley kurokoma-kun DIY / Maintenance / Service 5 04-06-2010 01:18 PM
DIY: Nonstop Tuning CR-LITE Crank Pulley *MAD DOG* DIY / Maintenance / Service 0 02-04-2010 04:46 AM
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
ZPI Racing Toyota Yaris 06-07 Lightweight Crank Pulley SebYRS Items for Sale by private party 7 06-19-2007 08:00 PM
