Old 04-30-2013, 02:30 PM   #1
jcboy
Drives: Sedan 07
the reason why you keep breaking fuses is that the relay's feed in 85 (from the stock wiring's +12V) is now shorted to 86 (ground) (or vice versa, whichever way you did it).
change your relay, and yes, weatherproof it, and youre good to go.
here's the connections as a refresher:
stock wiring +12V --> relay 85
battery +12V --> relay 30
horn +12V --> relay 87
horn (-) and relay 86 --> body ground
if you want you can insert an inline fuse from battery +12V to relay 30, your best bet is somewhere closer to the battery than to the relay.
makes sense?
Old 05-03-2013, 09:38 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
makes sense?
Yep, that's how it was wired. I just made the mistake of thinking that a few wraps with electrical tape would be sufficient to protect the relay. I was also lazy and put the fuse next to the relay, but that one didn't blow (I think).
Old 05-03-2013, 03:27 PM   #3
jcboy
Drives: Sedan 07
haha yeah i had exactly all the same mistakes with my previous car's horn wiring. i also kept destroying relays (about 4 times) and sometimes blowing the stock fuse because of that (twice), and never for once did my inline fuse blow. (that inline fuse was near the battery, before the wire to relay 30 terminal). too lazy to rewire the relay to the engine bay and not behind the front bumper.
and yeah, if your relay gets busted inside, it can either give an open circuit (safe), or a closed circuit (shorted, not safe) and blow up your stock fuse (where the +12V {that goes to relay 85} is wired from).
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
Toyota Premium Horn Install Meteorite_Marty DIY / Maintenance / Service 78 02-23-2013 02:02 PM
horn install ttr125fan09 Cosmetic Modifications (Exterior/Interior) 6 06-23-2012 07:42 PM
