Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 05-14-2013, 07:10 PM   #1
swidd
Drives: Yaris HB
So for option 6 b, fog lights on with low, high and park:
I will be plugging both wires from the switch into 13 and 3? But 3 doesn't connect to anything...
Am I supposed to just remove the wires that are in there already, and leave them hanging unconnected?
Old 05-14-2013, 07:50 PM   #2
Into the original Yellow wire 3 (you will put it back as it was when you started and then tap one of the switch wires to it and the other to the wire in pin 13).
Old 05-14-2013, 10:02 PM   #3
swidd
Drives: Yaris HB
So I have to remove the ends of the switch's wire and just tap 3 and 13... Okay :-)
I really didn't understand that from reading the manual. I'm not a smart man :-/
Old 05-14-2013, 10:38 PM   #4
There was always much confusion on that. It means that you need to split the switch's harness all the way to the switch, so that there are four completely separate wires, and then you need to extend some of them to reach where they need to go.
Old 05-14-2013, 11:38 PM   #5
swidd
Drives: Yaris HB
Now you just confused me even more. There's three wires coming out of the switch socket.
Black (which I grounded)
Green (in picture)
Red (in picture).
Where does each go? If I want to ignore the switch light and just have functional fog lights, can I stick with the instructions in 6(b) and just merge green and red to 3 and 13? And leave black grounded?
Old 05-14-2013, 11:56 PM   #6
Green (in picture)
Red (in picture).
Where does each go?
It depends on there position in the switch connector. There should be four wires entering the green connector.
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
Bulb Size For After Market Fog Light Kit razzorjet2 DIY / Maintenance / Service 1 04-10-2007 02:15 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
