Old 05-16-2013, 10:50 AM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
How are you going to put the square peg in the round hole?
Old 05-16-2013, 03:28 PM   #2
3cyltrbo
Tooter
Thanks for your replies
Just so I understand (I'm slow)
You have a tooter instock that is made to accept the 1zz and its $450 shipped?
Thanks
Will
3cyltrbo is offline   Reply With Quote
Old 05-16-2013, 04:50 PM   #3
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by 3cyltrbo View Post
Tooter
Thanks
Will
http://www.ebay.com/itm/Toyota-Yaris...item2c6d36b28c
JustDidIt is offline   Reply With Quote
Old 05-16-2013, 09:55 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Tooter
Thanks
Will
Yes I do, Will.
This is the picture of the actual 1ZZ ready tooter manifold that's in stock for sale.
It's $495 on ebay only because of the added fees. From me directly, it's $450 including shipping.
Greg
greggabi@verizon.net
310-455-3340
Old 05-17-2013, 12:34 PM   #5
3cyltrbo
Originally Posted by tooter View Post
Yes I do, Will.
Greg
310-455-3340
Other than a 1ZZ TB which I have already, what else would I need that might not be included?
Old 05-17-2013, 01:16 PM   #6
tooter
play every day
tooter's Avatar
Nothing.
The tooter uses all of your stock manifold bolts and throttle body studs. It comes with a OEM Yaris O ring manifold-to-head gasket, a OEM Corolla flat gasket between the throttle body and the tooter, and an OEM Corolla O ring gasket between the throttle body and the adaptor. All of the hoses will need some rerouting because everything is shifted to different locations. I ran some of the tubes under the throttle body for a cleaner appearance.
Old 05-16-2013, 10:16 PM   #7
tooter
play every day
tooter's Avatar
Only the round half goes into the round hole and is inside the plenum...
The square half sits on top of the hole on the outside of the plenum like the head of a rivet so as to hold the 1ZZ throttle body. The corners overhang on purpose so that it doesn't just fall through all the way. This will make welding really easy as it will rest exactly where it's supposed to be.
Old 05-17-2013, 07:18 AM   #8
Flipper_1938
Actually I was wondering about the "boob" to factory square intake flange.
Old 05-17-2013, 10:44 AM   #9
tooter
play every day
tooter's Avatar
I'm getting a round piece of aluminum plate and cutting a rounded square hole in it. The diameter of the plate will be slightly larger than the hemisphere so that it can sit on top of it, while the square hole will be slightly smaller than the factory runner retention flange to allow the plate to set on top of it.
After the welding, everything gets stainless steel bead blasted for a clean consistent uniform finish.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
