Old 05-21-2013, 04:46 PM   #1
Jason@SportsCar
Originally Posted by maxthehax View Post
Okai so if you are still using the stock ECM to run your drive by wire TB, this is because the EMS cannot by itself?? I have an 2005 echo, so my TB is the drive by wire...
Is there any other reason for you to keep the stock ecu installed?
Thanks very much for your fast informations!
Also, what about the wiring kit needed? Do you guys used the big 96'' with the relays & fuses?
The EMS 2 can not run the DBW. The new AEM Infinity is supposed to, but they only have limited applications so far.
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 10:33 AM
Standalone ECU d1nzfe Performance Modifications 11 12-24-2009 11:46 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
