Old 05-23-2013, 01:10 AM   #1261
TOLMACH
Drives: soarer
Originally Posted by tooter View Post
Wow... that one's only $199 and no reserve.
It looks similar to this design except that throttle body tips down and this one tips up.
back side view...
Mine had welding blobs in the runners like those except less of them because I found a really good old school welder who really knows his stuff.
Ask for Bill...
Ajax Welding and Sandblasting
7933 Gloria Avenue
Van Nuys, CA 91406
818-781-5667
I believe the above one is something similar to what weapon builds for xb http://www.ebay.com/itm/WEAPON-R-INT...6d3e2b&vxp=mtr
Old 05-23-2013, 11:11 AM   #1262
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yeah, a Scion manifold. And the two lower pics came up with a Richard Holdener image search.
Old 05-23-2013, 11:20 AM   #1263
The eBay one isn't just similar, it IS a WeaponR intake. (says so in the text for the listing, too)
He's added NOS ports and a different flange to it.
Old 05-23-2013, 12:11 PM   #1264
tooter
play every day
tooter's Avatar
^ Probably! Ooh... plus $35 shipping.
Injen intake for your truck would be $219.95 through us, by the way.
Part # INJ-PF2011
SOLD
I'll drop by with the money around noon today. (order the polished one, and not wrinkle black)
Thanks for the good deal, Garm!
Old 05-23-2013, 05:43 PM   #1265
^ Sorry I missed you today, tooter.
Old 05-23-2013, 07:11 PM   #1266
tooter
play every day
tooter's Avatar
I'll see you when the Injen intake comes in so you don't need to bother with reshipping it.
(cool green coupe... )
Old 05-24-2013, 12:11 AM   #1267
^ I can always drop it off as well.
thanks, the big 'ol Nash barn find has been a real fun project.
Old 06-01-2013, 01:02 PM   #1268
tooter
play every day
tooter's Avatar
Picked up the intake from MI. When I removed the plastic wrapping, I saw that the tube had a manufacturing defect which had nothing to do with either shipping, or Jeff or Garm so I'm dealing directly with Injen.
The tubing was crumpled where the machine gripped it to swedge down the MAF sensor area. Why they went ahead and polished the dents and sent it out is beyond me. Adrian, at customer service is making it right by sending out a good tube that isn't crumpled.
Got the tooter et back from Bill at Ajax Welding...
Now I can mount it on the engine to locate the proper attitude of the throttle body base/bellmouth in relation to the hemisphere.
That manifold on ebay ended up selling for just $250 including shipping which is a pretty good deal for an alloy intake.
Old 06-02-2013, 06:31 PM   #1269
tooter
play every day
tooter's Avatar
Put the tooter et mockup on the engine to position the throttle body.
Because the plenum is a hemisphere, the throttle body is free to be rotated and angled in any direction.
I also installed the stock air box as an alignment tool to precisely line up the body for a good fit.
Old 06-02-2013, 08:04 PM   #1270
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Genius! I'm still curious about how the hemisphere will be mated to the manifold. Or did you cover that already?
Old 06-02-2013, 08:30 PM   #1271
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Beautiful work! Does it come with a sound clip?
Old 06-02-2013, 09:59 PM   #1272
tooter
play every day
tooter's Avatar
This is the next step... punch a hole to insert the bellmouth.
Hey Cranky,
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer.
There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate. I'll also be inserting three aluminum tubes where the blue dots are for the hoses, so they'll also need to be welded into place.
Old 06-03-2013, 06:03 AM   #1273
CrankyOldMan
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer. There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate.
Aah, that makes sense.
Curious-er and curious-er. This thing really is going to look alien when you're done!
Old 06-03-2013, 10:49 AM   #1274
tooter
play every day
tooter's Avatar
Yes. The hose fittings are the antennae!
The manifold will be a lot more compact because a hemisphere is the most volume efficient shape for a plenum. This will move the throttle body to the left which is closer to its original stock location.
I'm totally curious as to what the effect will be as there are no flat surfaces for the reflected pulses from the mouths of the runners to bounce off of. The entire inner surface of the plenum, including the 180 degree rounded bellmouth of the throttle body bore, is 100% curved.
I just gotta find out what will happen. And the sales of the tooter products have bought the freedom to explore...
Old 06-03-2013, 11:00 AM   #1275
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Very cool build!
JustDidIt is offline   Reply With Quote
Old 06-03-2013, 11:28 AM   #1276
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
<--this guy is a alien sponser lol
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-03-2013, 12:32 PM   #1277
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
does it look phallic for Garm yet? :P
Old 06-05-2013, 04:49 PM   #1278
10 Francis
Drives: 2010 Yaris S HB
subscribed
10 Francis is offline   Reply With Quote
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
