![]() ![]() Drives: Yaris 2009 automatic Join Date: May 2009
I didn't keep checking them since there's a sensor for tire. I check when the light is on...last time I inflate it to about 38 to 39 PSI, the standard is 35 for this tire.
Would it be part of the factors also? Or only under inflated cause this problem? Thanks, Ricky |
#2 | |
#3 | |
How often should I check my tire ? Which level would start harming the tire? Thanks, Ricky |
With how light the Yaris is, you would need to be at least 10 to 15 PSI over the tire's recommended pressure before you would potentially hurt them.
Thanks all. I think I will go for Sears since most other place are about the same in final price. Cooper seems like a good brand...?
#6 | |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Thank you very much, I will check them monthly from now on, not a difficult job anyway.
I have a further question about this tire. My father said, "if they are not retreaded tire / refurbished tire, they should be fine." Because the rubber is made all at the same time instead of combining an old tire with new rubber (tread). He means it's not likely to suddenly shred a big piece of rubber and broken down on the road. Is he correct? (he's not auto technician, but his statement seems a little logical) Question 2 - Do Good Year or other brand make retreaded tires? Is the one I am currently using is one of those? It's Good Year Eagle something (They are the tires come with my car on the first day.) Thanks so much for all of you sparing your time with me. |
#8 | |
I would not expect the failure mode from that type of cracking to be shedding a large chunk of tread. I would expect it to eventually lead to an air leak or eventually a blow out, when the crack suddenly deepens.
I see... Thanks very much for your advice. A large chuck of tread shedding is what I worry about.
So those tire I purchased with a regular brand name like Good Year, Kelly, and so on, are not likely to be [re-make] tire. Thanks~!! |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| goodyear eagle LS tire crack on side walls | romram | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 04-04-2016 10:56 PM |
| DIY: Adding LED turn arrows to side mirrors | my2sense | DIY / Maintenance / Service | 10 | 05-28-2012 02:16 AM |
| Drivers side JDM taillight | jdmekcivic | Items for Sale by private party | 4 | 07-09-2011 01:57 AM |
| Clicking noise when jerking steering wheel side to side/hit bumps left side | eii | DIY / Maintenance / Service | 8 | 03-22-2010 06:46 PM |
