Old 05-22-2013, 11:48 PM   #1
romram
Drives: yaris hatchback
goodyear eagle LS tire crack on side walls
I got my Toyota yaris july 2011, in less than 2 yrs with 13,400 miles, I noticed my tires (all 4) which are goodyear eagle ls (OEM / date code 610) have cracks on all tires. I just wonder if some of you have same experiences, or can give opinions. I tried to check the warranty from Toyota dealer in CT, but told me to check it with goodyear dealers. any idea?
romram is offline   Reply With Quote
Old 05-23-2013, 06:29 AM   #2
That is definitely bad. The tread area is beginning to separate from the sidewall. Goodyear only has a 12 month defect warranty, but I would go ahead and still contact them:
http://www.goodyear.com/en-US/tires/...to-light-truck
Old 05-23-2013, 10:48 AM   #3
Hershey
Yes , I've seen this with the EAGLE . Tires had less than 25,000 miles . Do as CT states . Good luck and let us know the results .
Old 05-23-2013, 11:38 AM   #4
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
I just found that my stock OEM tires do not have any sort of warranty.
I have Bridgestone Turanza EL400's.
So I'm going to be replacing them really soon just in case.
I'd hate to end up in a new car with damage from a low end tire.
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-24-2013, 01:29 PM   #5
RedRide
RedRide's Avatar
IMO and this is only MO, the Eagle LS tires are garbage. They are so bad IMO that I took them off my Yaris at about 2k miles and got a set of (relatively inexpensive) Yokohama TRZ tires which although are not the best, are much better than the LS IMO, including in snow.
If you got 13,400 miles out of them, consider yourself lucky..... now get better tires and cut your losses.
Old 05-24-2013, 10:00 PM   #6
nookandcrannycar
Thanks for the pics. I couldn't remember which brand I had as my OEM set of 4. With your clear pics as a reference, I know I had these Goodyear Eagles (and now I won't have to look back in my records to determine which I had). My experience was different than it sounds as though it was or is for many others. I got 71,480 miles out of that set of 4.
Old 05-24-2013, 10:33 PM   #7
I never had any cracking issues with mine in the year I ran them. However, they had no grip anywhere, dry or wet. They are, by far, the worst tires I've ever ran.
Old 05-25-2013, 12:54 AM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Besides the quality issue, tread separation can also be caused by running underinflated. Don't continue driving on those tires. Get some decent ones.
Old 05-25-2013, 12:58 AM   #9
tooter
play every day
tooter's Avatar
You are a good driver, nook.
That's a truly admirable quality... making things last.
Old 05-31-2013, 07:11 PM   #10
soup1207
Drives: Yaris 2009 automatic
I recently have that issue also ..currently at 30k miles. I probably had noticed those cracks 5k miles earlier but do not worry until now since I am planning to drive to Canada. Now I feel I am lucky after reading you guys comment.
soup1207 is offline   Reply With Quote
Old 06-03-2013, 03:58 PM   #11
MUSKOKA800
MUSKOKA800's Avatar
Buy tires before coming to Canada.
If you get caught out here you'll pay twice the price for tires.
They're a precious commodity here.
Old 06-04-2013, 01:13 AM   #12
nookandcrannycar
'Goodtear'
I'm amazed I didn't notice this days ago when this thread last had the newest post.
I had great luck with them, but lots of others didn't and this word in the thread title could sum up the frustration some felt. Got to be the thread title word of the year so far.
Old 06-04-2013, 01:28 AM   #13
nookandcrannycar
^^^^^ Great point. I also thought a somewhat related point that CTScott made while answering someone else's question on another thread is extremely interesting. Namely, that the Yaris can handle a greater degree of tire overinflation than some other cars because of its light weight.
Old 06-04-2013, 01:35 AM   #14
Astroman
Modded Moderator
Astroman's Avatar
I disagree. I put about 40k miles on mine with great results. The last 2 years I ran them I used them as siped winter tires and they performed well up until they didn't have decent tread left. I always kept them at the proper air pressure. Even the 2nd Yaris the ex ended up with did very well with them and hers was two years newer.
But yes, the ones in the picture are unsafe. Replace.
Old 06-04-2013, 02:13 AM   #15
nookandcrannycar
with great results.
Good to know someone else had great results with these tires
siped
I'd never heard that term before. I had to look it up. One learns something new every day .
I kept mine at about 38 (a bit over proper IIRC) and stretched them a bit over the rated mileage limit. Now that I think about it, I think one person on that 'How long did your OEM tires last' thread got 90k. I can't remember if that person had the these Goodyear Eagles we had or the other OEM set that other people had.
Definitely. Sometimes an OP takes a pic and it is blurry or the OP doesn't capture what he or she is trying to illustrate re holding the camera at the wrong angle, or for some other reason. Not the case here. Great pic for the intended purpose .
Old 06-04-2013, 02:25 AM   #16
nookandcrannycar
'Goodtear'
Just noticed Goodtear = likely a typo. I still think it would be a humorous reference though, if one had a bad experience with the tire.
Old 06-04-2013, 08:30 PM   #17
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
OEM tires do have a warranty, same as buying a new set.
The Bridgestone warranty book is in you packet.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 08-03-2013, 12:34 PM   #18
romram
brought the tires to Mohawk last may 22, and charged for the percentage I used for the tires. spent $256.81. hmmmm. goodyear, you have a bad product.... I did not hear any feedback from YOU re: my old tires..... next time, I WON'T GET GOOD YEAR!!!
GOODYEAR TIRE RECALL?? sammy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 08-03-2013 12:30 PM
Crack on side wall... soup1207 DIY / Maintenance / Service 19 05-31-2013 10:59 PM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
