They are still developing that ITB kit, but at $1000 less than the ZPI turbo I'd be a lot happier to get this. $2500 including a full, pre-tuned standalone. First of all, you can spend the $1000 doing a proper clutch system to handle the increased power. Second, you have more tuning capabilities because your extra power isn't dependent on your car hitting a certain RPM.
Actually, the guy who owns the xA that is being used to develop the kit moved to this after having a bolt-on supercharger and realized the supercharger had caused a bit of blow-by. Scary. He ended up having to buy brand new pistons and rings. You could go turbo and internals on top of a setup like this for a Corvette-destroying Yaris. You're probably talking 10 grand worth of work, but who knows? Maybe we will see it one day. Last edited by ChinoCharles; 04-02-2007 at 09:26 PM. |
#2 | |
why would you do that? you can make your own itb's, of you can get the wiring figured out for less than that. why not get somebody to make a intake manifold and pair it with a bigger tb and go from there? |
#3 | |
i did and you said you would go with this before going with ZPI's turbo kit because some kid blew his piston rings after supercharging his XA.
i know you were asking about ecu pinouts for some kind of engine management but in the thread you posted the pic of the itb's and themn said your comment.
| ECU reprogramming | hystria | Performance Modifications | 12 | 12-14-2006 09:18 PM |
| HELP Plsneed ecu diag/ecu pinout vvt-i controller install | jbann | General Yaris / Vitz Discussion | 12 | 11-20-2006 11:15 PM |
| ECU for the 1NZ-FE in the Yaris | DJ_SpaRky | Performance Modifications | 16 | 08-09-2006 11:15 AM |
