Old 04-03-2007, 12:05 AM   #11
joey1320
joey1320's Avatar
Drives: Yaris LB
They are still developing that ITB kit, but at $1000 less than the ZPI turbo I'd be a lot happier to get this. $2500 including a full, pre-tuned standalone. First of all, you can spend the $1000 doing a proper clutch system to handle the increased power. Second, you have more tuning capabilities because your extra power isn't dependent on your car hitting a certain RPM.
Actually, the guy who owns the xA that is being used to develop the kit moved to this after having a bolt-on supercharger and realized the supercharger had caused a bit of blow-by. Scary. He ended up having to buy brand new pistons and rings.
You could go turbo and internals on top of a setup like this for a Corvette-destroying Yaris. You're probably talking 10 grand worth of work, but who knows? Maybe we will see it one day.
you will actually spend $2500 for the itb's before saving up another $1000 and go for the proven turbo kit???
why would you do that? you can make your own itb's, of you can get the wiring figured out for less than that. why not get somebody to make a intake manifold and pair it with a bigger tb and go from there?
joey1320 is offline   Reply With Quote
ECU reprogramming hystria Performance Modifications 12 12-14-2006 09:18 PM
HELP Plsneed ecu diag/ecu pinout vvt-i controller install jbann General Yaris / Vitz Discussion 12 11-20-2006 11:15 PM
ECU for the 1NZ-FE in the Yaris DJ_SpaRky Performance Modifications 16 08-09-2006 11:15 AM
