#1 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Cheapest DD I could find!! |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
#3 | |||
only issue, if you can call it an issue is that unless you have an dlc port splitter you cannot run more than 1 obd device, i have a blitz r-vit (a fancy scanguage) and i had to get a splitter cable to run both at the same time. battery power will never run out, the snapshot device used a very small amout of power, in sleep mode with the car off current draw was only .06 mA. Quote:
i was already with progressive because they were the lowest rate for identical coverage, i have been with progressive for 8 years and all the cars and house are all with progressive, every year i call them and hassel them about the rate and ususally it gets dropped a little. Quote:
if you dont put a lot of miles on your car or you dont drive at night often then its for you weather you drive fast or not, i am a very offensive driver, i do not drive slow and i do drive a "performance" yaris. wide sticky tires and lots of suspension upgrades helped me because i dont brake that often or slow down for corners, stop signs and red lights need to be anticipated so you dont brake to hard but since they dont take speed into consideration you can still drive as fast as you want. i did however take the snapshot out of my car when i go autox due to the lots of hard braking |
#4 | |
| "5 Driving Myths That Cost You Money" | PETERPOOP | Fuel Economy Forum | 10 | 05-24-2011 10:20 PM |
