Old 06-08-2013, 02:38 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
changing belt, need help, think I have a MAJOR problem
Tried changing my belt today. Got the top bolt loosened and tried loosening the bottom 14mm bolt but it would not budge. So I sprayed a little wd40 and waited, then tried again and stripped the bolt. then I got another 14mm socket that had less points on it and tried with it. Stripped even more. Now I got a pretty much rounded bolt.
what can I do aside from taking it to the dealer and them charging me $200 to replace the belt. (their quote a few weeks ago)
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Broke Part on Engine Changing serpentine belt. theeggrocks DIY / Maintenance / Service 5 04-16-2012 12:27 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
