Old 06-10-2013, 05:08 PM   #15
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
What has happened is you didn't apply enough force/torque on it. The socket is moving but the bolt will not budge then you end up stripping it. That's what happened to me. I stripped it as well. I realized i wasn't applying enough force down on it. So I got an extension. I used one of these
because I was kind of scurred at the time that I stuffed it up.So i just got something I could find. But it worked for me it helped to put down enough force/torque on the bolt.So the socket spun the bolt and not just the socket spinning around the bolt.
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Broke Part on Engine Changing serpentine belt. theeggrocks DIY / Maintenance / Service 5 04-16-2012 12:27 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
