![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
The bike ITB retrofit to a car has been around for awhile. I know that several Neons where running around with them. There was a big problem though. No MAP signal since there was no plenum. The other thing is that the Neon had an aluminum intake manifold so cutting the runners down and fabricating a mounting plate for the ITB's was worlds easier than the Yaris since you will need to have a flange cut and have the short runners and injector bosses.
There a whole shit ton of reasons that this is a bad idea.
ChinoCharles Intake supporter. |
| Turbo system | Thirty-Nine | Performance Modifications | 36 | 01-18-2007 11:25 AM |
| ECU reprogramming | hystria | Performance Modifications | 12 | 12-14-2006 09:18 PM |
| HELP Plsneed ecu diag/ecu pinout vvt-i controller install | jbann | General Yaris / Vitz Discussion | 12 | 11-20-2006 11:15 PM |
| ECU for the 1NZ-FE in the Yaris | DJ_SpaRky | Performance Modifications | 16 | 08-09-2006 11:15 AM |
