Old 06-16-2013, 01:43 PM   #1
Awesome, congrats on a successful install! Do you have it set on soft (21mm equivalent) or stiff (23mm equivalent)?
The installation instructions are sparse (and that's being generous).
For anyone else doing it, we provide a DIY tutorial, and I'm pretty sure there's one on here too.
Putting a jack under the shock lower mount to line up the holes allows you to slip the bolt in and out without much of a problem.
Old 06-16-2013, 04:13 PM   #2
arose62
Drives: yaris
Have to disagree, at least in my case. I was seriously thinking of cutting or grinding 2 or 3 mm off the end of the bolt, because it really looked impossible without removing the brake backing plate. Hence taking the time to post my experience...
When I check the install post-freeway drive, I'll take some measurements of the bolt length, abd gap between shock mount and backing plate - maybe something's changed on 2013 models?
Cheers,
Andrew
arose62 is offline   Reply With Quote
Old 06-17-2013, 08:41 AM   #3
arose62
Drives: yaris
I did 200 km to work and back today, with the rear sway bar on the soft setting, and I'm still excited at the improvement!
The run to work was in blowy, gusty weather, and I was no longer correcting the steering to keep the Yaris in my own lane. I could still feel the buffeting, but it wasn't moving the car around.
I sat beside a truck and trailer, and again found the car comfortably stable, unlike in standard form. Why don't Toyota put a rear bar on as standard ???
I also measured the supplied long mounting bolt - 110 mm, and the gap between the shock mount and brake backing plate - 100.5 mm.
No wonder I had dramas! There is an indentation in the backing plate, but no way is it 10 mm deep!
My dad's getting an identical Yaris next week, so if he decides to get the same sway bar, and there's the same fitting challenge, I'll take pics/vids to demonstrate.
Cheers,
Andrew
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
WTB: Rear sway bar weedtank Willing to Buy by private party 4 02-08-2012 01:50 AM
Rear sway bar snow clearance? CrankyOldMan Performance Modifications 19 09-15-2011 01:40 AM
FS: TRD rear sway bar 19mm brand new in box hksir Items for Sale by private party 7 02-12-2011 08:07 PM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
