#1315 |
2ZR swap. DO IT! Ask how!
So many Freudian themes in this project! I was wondering where the actual seam would be on the bellmouth--for some reason I was thinking you would put it all the way up to the squared shoulders.
#1316 |
It looks from the picture, that because of the angle, the throttle body points more directly at two runners, which are slightly further away. See your second picture above. It would be interesting to see a flow test for to see how much each runner is getting.
#1317 | |
play every day
It took a couple of hours of handwork to get the fit as precise as possible, and I'm totally satisfied with the results. ![]() ![]() When I bead blast the whole assembly to normalize all of the surfaces, you'll hardly be able to see the seam even with no welding. The raised square corners will end up working out nicely as the whole circle of the contact seam is easily accessible to be welded from the outside of the hemisphere. Exploring how to make the best of each detail in the design process is what makes this project no end of fun.
#1318 | |
play every day
![]() ![]() This is the original manifold throttle body axis orientation. ![]() And this is the tooter et throttle body orientation. ![]() This is why I don't believe that it was ever an issue. First because the flow is so direct, and second the runners are pulling from the plenum That's what I like most about this particular design. It completely eliminates the 90 degree "kink" runner to throttle body axis orientation found in all of the other typical plenum designs. Last edited by tooter; 06-24-2013 at 09:17 PM. |
#1319 |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Looking ever sooooo smooth!!! Nice!!
Why strive for a JDM BB, when you can promote the Scion badge? |
#1320 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Is it done yet?
#1321 |
^ He is currently testing it on Alpha Centauri.
#1322 |
Modded Moderator
Hey that's the post I see the most on my thread, Something Big is Coming!
#1323 |
play every day
#1324 |
play every day
The machine shop at Origin Designs made two more flanges. Their work is impeccable...
![]() Also got a Corolla manifold to build into another tooter.
#1325 |
Nothing like billet jewelry.
#1326 |
play every day
Here's the CNC machine making tooter intake manifold flanges two at a time...
![]() http://www.youtube.com/watch?v=rh4Ho5tI8KA |
#1327 |
play every day
Picked up the tooter et plenum to runner connecting plate today. It's far beyond what I had expected!
The plate fits so precisely to the runner base, I couldn't pry it off so I'll just leave there to be welded on. the hemisphere sets on a ledge and centers itself.![]() ![]() Now I'll do one last on the car fitting to rotate the hemisphere and mark the best attitude of the throttle body to line up with the intake. ![]() ![]() ![]() Next, the hemisphere will be drilled to accept some aluminum tubes for the three hose fittings. Then the whole assembly goes off to the welder! |
#1328 |
Modded Moderator
Looks great!
#1329 | |
Looks like quality design and manufacturing! I'm anxious to see how it works. |
#1330 |
play every day
This is just a one-off "outside the box" experiment that will never see production because it's not cost effective. It's pure exploration just for the sake of curiosity.
#1331 | |
After all, you now have a parts list (with math data). |
#1332 | |
play every day
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
