Old 06-29-2013, 10:47 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Bought a new belt today, and a metal can of denatured alcohol as prescribed. Used a wad of "blue" shop paper towels and dumped the stuff on it and wiped each one of the pulleys. I turned each one and they all turned freely except of course the crank pulley. The crank pully was impossible to get the papertowel all the way around so I took off the front wheel and go to it as best I could. There was about 1/4 -1/3 of it I just couldnt get with the paper towel. I then put on the new belt and pried as hard as I could with a pry bar on the alternator as my son tightened the bolt. The I tightened both bolts. Started right up no squeal.
Drove to walmart. When I started my car up at walmart to come home, squealed a little. Let it sit in my driveway a while and started it up again, and it squeals for the first second of starting again.
WTF??!? I'm about to go mad with this squealing belt and squeaky rear drum brake!!! LOL.
Do I just need to take that belt of and somehow just dump that denatured alcohol all over the inside of that dang thing?!? (or at least best I can get all over the pulleys?) Do I need to buy another stinking belt?
If I pry any harder on that alternator I'm afraid I'm going to break something.
Old 06-29-2013, 11:24 PM   #2
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
Don't give up !!
A lot of times you have to go back and re-tension the belt as it will stretch after the initial install. Also check your alignment. Also enlist some help, someone to tighten the bolts while you are holding the tension, it makes a big difference. Good Luck !!
alanwagen is offline   Reply With Quote
Old 06-30-2013, 04:26 AM   #3
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Don't give up.
But take it to a mechanic just in case.
I think it takes experience and plenty of practice to get it just right. What belt
did you get? the Toyota belt I got doesn't squeal. A mechanic can do your belt
up for 30 to 50 bucks.
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Seat Belt Problem wagon DIY / Maintenance / Service 1 03-06-2013 10:37 AM
Yaris problems heavenswaitin DIY / Maintenance / Service 3 11-02-2011 01:08 PM
NST Crank Pulley Reliability? WeeYari Performance Modifications 59 02-10-2010 01:20 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
