![]() Drives: 2008 Yaris Join Date: Mar 2013
Airbag light stays on dashbord
The "airbag" light on the instrument panel has been staying on even after the engine starts. Its is intermittent though, sometimes when I start the engine the light turns off like it is supposed to, but sometimes it stays on and when it stays on it will stay on while the engine is running. But later when I get back in the car and start it, it will turn off. I don't even know where to start to look. Any help would be great, Thanks.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Where is OC?
There are some excellent threads on this topic here on this forum. I had your issue, and fixed it for $50ish. Dealer price is ~$800. Like you, sometimes it would remain off after starting, but then turn on after a while. It is most likely the clock spring in your steering wheel. It explains why it sometimes takes a while before the short happens (you turn the wheel..., the cable wire inside moves kinda random) You will need: http://www.youtube.com/watch?v=LgWSzVeILhc Note you need a special screw driver head for the two bolts on the side. 19mm socket for the wheel. Disconnect battery, ensure you retain the zero on the clockspring and steering wheel. eBay seller I purchased from - quick delivery, sealed/zeroed with a plastic tie http://www.yarisworld.com/forums/showthread.php?t=39333 http://www.yarisworld.com/forums/showthread.php?t=32554 This thread helped me, and I posted an update to my own issues there. http://www.yarisworld.com/forums/sho...67&postcount=6 You can go ahead and generally thank CTScott upfront, as he has already solved your issue. Last edited by swidd; 07-06-2013 at 09:08 PM. |
OC is Orange County, in California.
Thanks swidd for getting all the info together in one place for me and thanks CTScott for providing all the info that swidd got together. I will do all the checks this weekend. |
Yep :-)
I just ordered the clockspring before even checking the codes, because the symptoms were such a perfect match to what CTScott described in the various threads. Reading codes was tricky; I believe the best method (which I didn't do) is to remove the little box above the ODB port, and insert paper clips from above. I connected crocodile clamps with wires to the paper clips so I could short it while also sitting in a position to see the codes flash on the dashboard. And note that even if 51 is the code for clockspring (and some other possibilities), I had two unrelated codes that also went away after replacing the clockspring. |
#5 | ||
Drives: 2008 Yaris Join Date: Aug 2012
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
Hooray, OC.
My 07 Yaris has the same problem before, Airbag light was on, then off. And it seemed to vary with the angle of the wheel. Replaced it, and fixed it. If I had to do it again, I would buy a new original. A 3rd party one I bought from ebay lasted only 3 months. |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| Fan Not Spinning Up, Random Airbag Light | drannonb | DIY / Maintenance / Service | 12 | 10-23-2012 03:33 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
