Old 07-06-2013, 09:06 PM   #4
swidd
Drives: Yaris HB
Yep :-)
I just ordered the clockspring before even checking the codes, because the symptoms were such a perfect match to what CTScott described in the various threads.
Reading codes was tricky; I believe the best method (which I didn't do) is to remove the little box above the ODB port, and insert paper clips from above. I connected crocodile clamps with wires to the paper clips so I could short it while also sitting in a position to see the codes flash on the dashboard. And note that even if 51 is the code for clockspring (and some other possibilities), I had two unrelated codes that also went away after replacing the clockspring.
swidd is offline   Reply With Quote
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
